MOHAMED HAMDALLA
CMA of Twisted pair
Hi all
I am trying to simulate an unterminated twisted pair using CMA.  every time it shows me an error. "Characteristic mode analysis cannot be used when the number of MoM basis functions is zero".This is also the same case when I terminated the cable with resistance. If I use the MOM in the harness properties it gives me another error "The combined MoM/MTL solution method may only be applied to shielded or single conductor cables". Is there a way to apply the CMA analysis on the unshielded (terminated/unterminated) twisted pair?
Thanks
UTP-cat6.cfx
I would suggest that you not try to use cable analysis if you are interested in CMA. As the message indicated, CMA is only supported for MoM and the MoM/MTL is a very special hybridisation that is only applicable for shielded cables. I also don't think you are going to get out of the simulation what you want if you try to use cable analysis.
I would simply model the actual twised pair using segments (as a start or even cylinders - only for very short cables and high frequencies).
Out of interest, what are you trying to investigate with CMA and twisted pair cables?
