Karthic
Fatigue sequential loading
I am trying to learn fatigue using optistruct , Please share me with the videos and fem files regarding fatigue. I already went through the fatigue tutorials in optistruct
If I put all of the fatload into one fatevnt, are they now occurring simultaneously? How do I change the model that the loads occurs one after each other?
Thankyou
N.K
Hi @Rahul R,
I tried using the SQNTL in FATEVNT load collector.
I got error " TID field in FATLOAD 9 must be a blank because of SQTNL  in FATEVNT 10. "
Tried leaving the TID field in FATLOAD 9 blank. Resulted in some other error " ERROR # 1000 *** in the input data:  Incorrect data in field # 3."
Please guide me how to clear the SQNTL loading errors
Thank you
18 hours ago, Prakash Pagadala said:
Hi @Karthic
Can you please share the .out file?
Hi @Prakash Pagadala,
I have shared the files,
BrakePedal.fem
BrakePedal.out
HI @Karthic
I agree. But in document it says TID should be blank,
I have written to experts on this to get a clarification. I will update you soon.
Hi @Karthic
Right now sequential loading is not supported with tabfat.  SQTNL is used for rotor dynamic cases for example.
Concern team is going to add more information on SQTNL soon.
if at all SQTNL wants to be used, then you  would have to create separate events
47 minutes ago, Prakash Pagadala said:
Hi @Karthic
Thank you for the quick response.
1. So you mean sequential  loading without TABFAT is OK ?
                                                      OR
2. Creating  separate events and calling all in FATSEQ card is ok ?
