Alan
Customized design variable
Is there a way i can create a customized design variable? I want relative density as design variable. and in that case, Young's Modulus(E) and density (Rho) will change accordingly with customized relationship function between relative density and E/Rho
Thank you,
Alan
Yeah i understand that i can change it to "E" and "rho". @Mrt
but what i meat was to have E and rho with a relationship in between. assume E = 0.5 * rho. each value of rho corresponds to only one E value.
For material property HS-4200 is more relevant tutorial. For Linking Input variable you can refer HS-1060.So link variable will work in your case.PFA sample image for your requirement.
