EmSt
Coil: resistance --> resistivity
I have to model a coil with the resistance of 2Ohm. How can I realize it? The Application is "transient Magnetic 3D". In the Editor for a non meshed coil i can define the reistivity of the coil. But I only know th resistance of it. I can't use the formula resistance=resistivity*length/A because I don't know the length of the wire.
In the circuit Editor conextI use a coil conductor. There I can define a resistance.
Is this the same?
Thanks.
Tank you very much.
What is a phase resistance?
And is this the same as the resistance of the wires from the coil?
Thanks and best regards.
