Hi all,
I'm working on a project right now and trying to figure out how to see all the notes saved on the Rhino model in Hypermesh. I've tried using the hm_metadata command but it only returns the notes applied to the whole model. Is there any other metadata command or an option I can add to hm_metadata to see the attributes given to individual solids/surfaces/points? Are these attributes even carried over in the IGES file?
Thank you in advance,
Alex
Hi, this command will return all metadata. If you don't see it, that means it does not exist in hm file. check you cad software document again.
hm_metadata findall
