Hi dear support Forum!
I want to automate the process of converting *.fem to *.h3d files for the FlexBody option in MotionView. In tutorials the FlexPrep interface in MotionView is presented, which is ok but not feasible for large quantities of files.
Therefore I want to automate the flexprep step, which also should be possible according to:
https://altairhyperworks.com/hwhelp/Altair/2017/help/mv/mv.htm?flexprep_mv.htm
From the help section I've interpreted the command line to be:
"C:/Program Files/Altair/2017/io/translators/bin/win64/flexprep" "C:/Temp/mbd/Body1.fem" "C:/Temp/mbd/Body1.h3d" CB +17079+17080 10 -STRESS -STRAIN
Which is identical to what the user interface in MotionView calls in the file:
C:\Program Files\Altair\2017\utility\mbd\custom_wizards\flexpreptk.tcl
The conversion works perfectly in MotionView:
**                    Altair Flexible Body Preprocessor                     **
**        Flexible Body Modal Synthesis and Data Translation Software       **
**                      from Altair Engineering, Inc.                       **
** Executable flexprep 2017.2.0.16
** Time of Build 17:27:47
** Date of Build Jul 25 2017
** Copyright (c) 1996-2017 Altair Engineering, Inc.  All Rights Reserved.
Contains trade secrets of Altair Engineering, Inc.   Copyright notice does not imply publication.
Decompilation or disassembly of this software is strictly prohibited.
**INVOKING <CRAIG-BAMPTON MODES> PROCEDURE**
 (ORTHOGONALIZED FIXED-INTERFACE EIGEN AND CONSTRAINT MODES)
 RUNNING FLEXPREP USING OPTISTRUCT ...
** Time of build : 15:07:05
** Date of build : 06/16/17
** Time of build : 15:17:26
** Time of build : 15:08:18
Total Translation Warnings and Errors:
Warnings: 0
Errors: 0
 **                         OptiStruct 2017.2                          **
 **             Advanced Engineering Analysis, Design and              **
 **        Optimization Software from Altair Engineering, Inc.         **
 **             Windows 10  (Build 9200)  DESKTOP-4115EKL              **
 **          4 CPU:  Intel(R) Core(TM) i7-3540M CPU @ 3.00GHz          **
 **                     3804 MB RAM,  9346 MB swap                     **
 ** Build tag: 0872785_9433172_Ce64RBW8UH14M:131848-2  4000            **
 **  COPYRIGHT (C) 1996-2017                 Altair Engineering, Inc.  **
 ** All Rights Reserved.  Copyright notice does not imply publication. **
 **         Contains trade secrets of Altair Engineering, Inc.         **
 ** Decompilation or disassembly of this software strictly prohibited. **
 *** OptiStruct defaults set from:
   install config file: C:\Program Files\Altair\2017\/hwsolvers/optistruct.cfg.
  Much more mumbu jumbo down here.....
But when I run the line in command prompt I get the following error:
'optistruct.bat' is not recognized as an internal or external command,
operable program or batch file.
'"optistruct.bat"' is not recognized as an internal or external command,
Warnings: 0
Errors: 0
Therefore I changed the working directory in the command prompt to the location of the optistruct.bat, but that yielded this error and the optistruct part doesn't start:
Warnings: 0
Errors: 0
There must be some sort of environment variables missing for flexprep to run perfectly.
Hence the question: Is there a workaround?
Thank you in advance and best regards!
