Sign in to follow this
florian_lw
Curve Interpolation
Hi all,
i want to interpolate each of the four curves to 1000 points (orginally 1500 to 1900 points). Which function can i use?
post-3178-0-30852600-1386751999_thumb.pn
Is it possible to create a best fit mean curve in HyperGraph? which function can i use for this?
try the following:
1. Menu->Curves->Plot Macros
2. Select the function "resample fixed points"
3. Double click "Curve" and select your curve
4. Select a value (e.g. 1000) for "Number points x-vector"
5. Press "Apply"
Best Regards,
Mario
PS: Hoffe es klappt ;-)
