Hi all,
I'd like to use Matlab to control OptiStruct -- change design variables and run the analysis. My intent is to use numerical methods scripts I've written in Matlab and loop back and forth between Matlab and OptiStruct. The process would run as follows:
1. Matlab -- numerical methods algorithm takes in FEA results, outputs design variables
2. Optistruct -- takes in design variables, runs FEA and outputs results (.out file)
3. Repeat
Can anyone help me run OptiStruct from Matlab? More generally, does anyone have experience running OptiStruct externally?
Thank you in advance for any help!
Best,
Alex
Hi Alex,
Were you able to solve this? I want to run a code that changes the .fem file, calls optistruct to run the linear analysis and checks the compliance. After that it will repeat the process till it reaches convergence. How do you get matlab to run optistruct?
Thanks,
Rodrigo
This is very complicated but can be done:
%uploading a .fem to optistruct and reading punch file using matlab
%step 0 add punch card request(s) at the top of the file
% DISPLACEMENT(SORT1,PUNCH,REAL,NORMAL) = ALL
% ESE(PUNCH,PEAK) = ALL %element strain energies (for compliance optimization)
% GPFORCE(PUNCH,REAL) = ALL
% GPSTRAIN(PUNCH,GLOBAL,ALL) = ALL
% STRAIN(SORT1,PUNCH,REAL,ALL) = ALL
% STRESS(SORT1,PUNCH,REAL,ALL,CENTER) = ALL
%step 1 get path to fem
path_new_fem = "INSERT FILEPATH TO FEM FILE HERE";
%step 2 get path to optistruct
loc_opti = 'C:\Program Files\Altair\2017\hwsolvers\scripts\optistruct.bat';
%step 3 send to solver using system() or dos()
command_string1 = char(strcat('"',loc_opti,'" "',path_new_fem,'" -monitor'));
answer = system(command_string1);
%step 4 get path of the punch file
punch_path = 'INSERT FILEPATH TO PUNCH FILE';
%step 5 read the punch file
PCH = reading_punch(punch_path);
Using this code, matlab will run optistruct. One thing I have not included is the reading_punch code, which reads a punch file output from NASTRAN/OS. If you need this let me know, however I am certain punch file readers exist for matlab online already.
If you are going to do it this way, you will need many other scripts, including one which will take your input variables calculated by matlab and write them to an FEM file. The punch reader can be used to read outputs from OS to matlab such as stress etc. What you will need is heavily dependent on what you are trying to do.
