mOaR89
Curved tube meshing problem
Hi All,
I'm Newbie and I started working with Hypermesh 2 weeks ago and i hope to find solution here for my problem :) .
I want to mesh a curved tube. But first I tried to mesh a straight tube, created with two circles and a line connecting these circles, and it worked fine (see picture named "straight_tube") with the skin panel. post-21421-0-91084400-1391351196_thumb.j
Then I tried the same with a curved line using the spline panel. But it only meshes the half of the tube instead of creating a closed mesh (see second picture "curved_tube") and I don't know why. post-21421-0-47037200-1391351195_thumb.j
Do you have any idea of how to fix this problem?
Thank you in advance
Best regards,
Uysal
If your curved tube is correctly make (geometry) , try to cut it into 2 or 4 parts. Make the mesh for each.
