Toan Nguyen
Find nodes assigned to a system
6 hours ago, Toan Nguyen said:
hi,
I am looking for a solution to find out the IDs of nodes assigned to a system which I already know the ID.
Is there anybody having any ideas how to do that ??
Hi @Toan Nguyen
this could work for you.
set sysId 1
hm_getcrossreferencedentities systems $sysId 7 1 0 0 -byid
hm_getmark nodes 1
tinh and Toan Nguyen like this
@tinh
It is an output system which is used to set displacement of nodes on that system.
@vipin
It doesn't work with the following message:
hm_getcrossreferencedentities: unable to find the entity by id " "1"".
Please note that the system with ID 1 existed in the model I used for checking
test_model.hm
3 hours ago, Toan Nguyen said:
@tinh
@vipin
test_model.hm
So you found answer base on my *createmark command, didn't you? ;)
I searched it by inputsystem
