MarcelK
Analysis Failure - geometry failure
Hello everyone,
i have a problem with running a analysis with solidthinking inspire 2017.1
The modell consists of two bodies which are connected via several bolts.
When I was importing the two bodies there has been a alarm message that there is some failure with the geometry. But after checking the geometry of both bodies manually, no mistake has been found.
Inspire also asked to repair geometryfailure but imported the data with failure.
I also tried to reduce the minimum thickness and element size as prompted in some analyses before.
How can I find out in inspire, where the geometry is, which inspire can't interpret correctly?
I attached a screenshot of prompted alarm message while meshing and also the inspire modell.
Any help will be highly appreciated. Thank you in advance.
Kind regards
Marcel
02_QM_02_01_Knuckle_split.stmod
