Sign in to follow this
Aslan
Lattice Structure Type
Hı I am trying lattice structure optimizatons. Actually I can do it.
I want to change lattice types such as 1,2,3,4 and than results compare but I dont have any difference.
If you know solution for this problem,can you help me?
Thank you
Hi @Busra ASlan
So you are changing the lattice type from 1 to 4. But you don't see any change in results...
Is it in structure or FE results you don't see any change?
thank you.
I will check and update you soon. Since you are interested in the results, I will try to post the results ASAP!!
HI,
I tried on a test model and I see the difference in structure and results as well. But this is not happening in your case and the reason I think is of the design envelope.
I will write to Dev team about this for a better explanation. I am attaching a PPT with my test model.
Lattice_CA.pptx
Yeah, so tetra elements take only one type. Whereas Hexa elements are compatible for all types of the lattice.
On 9/7/2018 at 7:18 PM, Busra ASlan said:
Thank you @Prakash Pagadala
I tried to make a hexa element using 3D-solid-map for mesh structure. And then I got a solution for 1,2,3 types but  the analysis results are zero for 4 is a solution.
Can you help me?
Can you share the .out file for the type 4 lattice optimization?
