Staedtlerp
Honeycomb modeling with shell elements
Good morning all,
I'm modeling a composite laminate made of carbon fiber layers and honeycomb.
I'm modeling using the pshell elements and MAT8 card. The question is that I don't really know how to fill the material card entries.
I'm using Nomex honeycomb and the properties provided by the supplier are those depicted in the attached photo.
Using MAT8 I need 9 mechanical properties (E1, E2, NU12, G12, Xt, Yt, Xc, Yc, and S, excluding density) but I haven't got these properties and I don't know how to insert the properties provided by the supplier's datasheet.
Can anyone help me??
Thank you very much
I generally model Nomex honeycomb in the same way, and would make this MAT8 card for that core:
MAT8           1     1.0     1.0     0.3      1.0   41.0    20.0  3.2-11
                                     1.0      1.0    1.0     1.0    0.35
EDIT: You can put the real strengths in if you like, but generally I just use 1MPa since I don't check the failure of the core within my FEM analysis. I use 1.0 for E11 and E22 since the honeycomb doesn't carry load in these directions - the skins do.
Rahul R likes this
Hi @Staedtlerp
Is there a reason for modeling honeycomb with the shell?
The std practice is to model with solid elements. but if you have a very large honeycomb cell size, shells can be used effectively as long as you are not resin filled.  If your core is a significant thickness in the total composite, it would be more appropriate to use a solid representation anyway rather than assuming it is a "layer" in a composite PCOMP
19 hours ago, MattM said:
It depends on the model and the part. For example we don't use solid elements in GFEMs of whole aircraft models in the aerospace industry.
Yes, because of their large size.
