I need some help in the use of bushings. I need to know the right way to use it. I tried to read the Online Help but I didn't understand how to use it.
What is the difference between the use of a compliant revolute jont and a bushing?
Thanks
Stefano
Hello Stefano - There is no difference between a compliant joint and a bushing except that a compliant joint gives flexibility to toggle between the compliant and non-compliant state.
Regards
Praful
On 9/1/2018 at 6:16 PM, stefano1 said:
I need to know what should I put into the curve as x and y variables in order to obtain the curves for translational stiffness.
 Thanks
Stefano
@stefano1
If you have curve data in .csv file, you can use FIle and refer the file for both X and Y or you can use Math to input curve data.
Sign in to follow this
