Nigue001
Plotting natural frequency
Hi there. I got a problem, i want to plot the amplitude of a simple spring-mass-system in HyperGraph.
The problem is, i don´t know which load steps or control cards i have to define.
This is an example how it should look like:
I need to know how to do that because in the next step, i have to design a
spring-damper-system to visualize the damping with HyperGraph.
I would any appreciate any help of you.
Greetings
Greetings
What type of analysis is it?
If it is FRF analysis,  for example, you can request Displacement and plot graphs. You should also see a .freq.mvw which has all animation and plotting information.
Thank you for your reply!
I tried to use "normal modes" analysis but i with this, i´m on the wrong way.
I only learned the basic knowledge of HyperMesh and now for a research
i have to deepen my knowledge in damped vibrations and forced vibrations.
Should i try it with FRF analysis?
So now i runned (with help from the tutorial OS-1315) a transient analysis and this
looks good so far. But now i got another question, is it possible to replace the
dynamic load with a mass point?
Furthermore, i got the problem that i am not able to get the
natural frequency anymore.
For better understanding maybe the files will help.
TestTrans.h3d
TestTrans.mvw
TestTrans_tran.mvw
I´m also new to Hypergraph and MotionView and I have two questions. I designed a simple spring-damper system with MotionView.
After starting the simulation, is there a way to display the frequency of the signal and adding an enveloping curve in HyperGraph?
Greetings
