ShaoibShaikh
*** INTERNAL PROGRAMMING ERROR # 8006 ***
Hi, I'm getting the following error while trying to run a modal analysis in Optistruct. Could anyone help me make sense of this?
ANALYSIS RESULTS :
ITERATION   0
 *** ERROR # 825 ***
 The run will be stopped due to the previously encountered fatal error
 from the element generation routine in preprocessing:
    Number of failed elements = 1
  Last encountered error code = 15
 The previous error is encountered in subroutine prpdrv.
 This error is issued in subroutine elqcdrv.
 Data block effmas not in data manager dictionary.
 * DATAMANAGER ERROR in subroutine "locateit".
 ****  Error 8006 in datamr() during "locate" operation.
     Data block name "effmas".
     Current memory allocation  8166 MB,
    Unused memory              6248 MB,
    Number of blocks: 280 used, 5 free.
     Call arguments 0, 0.
 *** INTERNAL PROGRAMMING ERROR # 8020 ***
 Failed database modify command:  Locating array effmas.'
 * DATAMANAGER ERROR in subroutine "LOCATE".
 This error occurs in module "wrtdrv".
Any updates on the topic?
I receive a similar error:
 A fatal error has occurred during computations:
  *** ERROR # 825 ***
     Number of failed elements = 2
   Last encountered error code = 99
Hi @seyilmaz
Can you let me know which version of HW you are using?
If the application is not updated, I request you to update the solver to the latest and try again.
If that doesn't help, please share the .out file.
Quote
Hello Prakash,
I have solved the problem. It is the CBUSH definition for me. When I defined CID in Card Edit for the Cbush elements that I have created, the problem is solved.
