Sign in to follow this
dajeet
1d beam element modeling
Hi dajeet,
assuming the units are ton,mm,s,N,MPa it seems that the beams are too slender (0,5mm radius) for a cantilever with 125N total force with and a moment arm of 1000mm.
So despite being made of stiff material (carbon fiber) this structure would deform excessively IMHO .
I suggest running size optimization to determine proper dimensions.
Hi, Ivan:
   thank you very much for the help.
sure, i will give a trial for size optimization and find the best diameter of the tube
i may need more help on this optimization side, i will keep you posted.
