Stephan Karth
Apply g-load for Topology
Dear all,
I'm new to inspire and currently checking the trial to make sure is fulfils our requirements.
I want to apply a 15g g-load to a cabinet that is attached to the ground. The g-load appears perfectly in the Analysis and the displacements make sense.
Unfortunately the topology optimization doesn't recognize the g-loads and breaks showing 'insufficient loads'. Is that a software bug or do I do sth wrong?
Anyone that has a similar example to show me?
Thanks a lot!
Stephan
Design and Non-Design space --- G force = 15g upwards on all parts
Factor of Safety in Analysis works fine
Loads insufficient for TopoOpt --- Error
Hi Stephan,
thanks for your detailed question. There are two things which are influencing your result, you may could do better:
  • You are asking Inspire to create a high efficient design (optimization) for a load which depends on the Volume itself. Just imagine what design you would create If anyone asks you to minimize Mass or maximime stiffness of a designspace which is direcly influenced by gravity itself. The best design would be to have no Mass at all!
    • In ur case you should add more areas of nondesign space around the desingspace, which can't be removed by the optimzation.
  • If you want to minimize mass by setting a factor of safety (fos), it could be possible that there is no solution for your aim.
    • The fos you want to achieve could be too high -> you won't get a result from optimization
    • The fos you want to achieve could be too low -> you have to reduce the minimum thickness constraint, so inspire can create smaller structures which fullfill the objective
x92vq1Og8l9UwAAAABJRU5ErkJggg==
BR
Felix
