Captain
PolyNURB Wrap/Bridge Feature Fault
It usually happens when you perform the bridge between two faces which are obtuse, So the faces get pulled resulting in a twisted geometry. This results in self intersecting case.
Try removing a cage or two using Shift + Select in +/- mode. Then add section/bridge. Also try aligning faces before bridging,
