Captain
PolyNURBS Mesh Export
Hello Max,
you can try the following:
  • At Inspire right click your shape and select "Save to Evolve"
  • In Evolve import the shape with "Retrieve from Inspire"
  • Your model is complete imported, including polynurbs
  • Select "Edit Polynurb" and pick your shape
  • At the "Edit PolyNURB" dialog you can deselect the switch "Nurbify" (at the top)
  • Export the geometry, e.g. STEP
  • Import it into Hypermesh and you can see only the Polys without Nurbs
Hopefully it works,
Best regards,
Mario
