Captain
Modeled PolyNurbs Body not visible - Bug?
Hello everyone,
I imported an stl-file in acsii file format in Inspire and modeled it with the PolyNurbs tool, but when i leave the tool, the body either isn't visible anymore or only one face is visible (as shown in picture 3). Is this a known problem?
Thank you
Max
please use the "measure box" to check the dimensions of your imported stl. You can use "Scale Part" to modify the dimension if needed.
wcoXu4ouskUmwAAAABJRU5ErkJggg==8DfP8QfIO3nZQAAAAASUVORK5CYII=
If your model was in the wrong scale, this should fix your issue.
Let us know, if this helps!
Felix
