InspireUser
[Urgent]: Tying (constrain) surface?
Merry Christmas everyone!
I would be grateful if someone gives a quick solution to this in midst of the holiday.
The red circled outer surface is bent upon compression of the structure. Can I constrain that surface so that it remains straight (vertical) as it were in the initial undeformed state?
Thanks.
Well, you could also create another support and activate all degrees of freedom, exept the one you do not allow any movement:
wfd8hxu0JceBwAAAABJRU5ErkJggg==A5nGAH6h9bsQAAAAAElFTkSuQmCC
You have done this already on the left side of your model, to constrain the deformation.
Felix
Well, that is the problem, that region of the structure actually moves in all 3 directions. So it needs to be free to move but remain in its original straight shape.
