Victor1535394411
Question about Compose
Sorry if I put the topic in the wrong place but I can't find the forum for the compose although it's a component of solidThinking.
My question is: how to import the '.mat' file into compose? Is it possible? My existing '.mat' is more than 1Gb with a lot of data and structures.
Thank you guys!
Hello Victor,
Can you please try the load command to import the MAT file? Eg: load ('file.mat')
Here's some more help on the syntax:
load:
Reads the content of a MAT file.
Syntax:
R = load(filename)
R = load(filename, variable)
load filename
Inputs:
filename
Path and name of the MAT file to load.
Type: string
variable
List of the variables to load, separated by a comma.
If no variable is specified, all variables are loaded.
Type: string
Outputs:
R
Struct with values read from the file.
Type: matrix
