engineblock
Slicing a solid body
I have just recently started working on Inspire to perform topology optimization. There is an issue which apparently I am not sure if Inspire can do or not.
Like in ANSYS, there is a "slice" feature where an imported solid body (as .STEP or .IGS) can be split into multiple portions using planes. Is there something similar available in Inspire as well? I need to separate some portions of the solid to exclude from design space. And I believe I cannot do that unless I split the solid body as the design space is selected as a whole in case of a part that is single body.
Looking forward to some hints.
Warm Regards
