Sign in to follow this
6nwuy
Saving optimised shapes - To continue working on at a later date.
I am having some trouble using the software.
A few days ago I ran several simulations within the same window (around 4 in total - each taking 2 hours each).
My plan with these was to save and look at the results the following day and compare the optimised results.
I saved this file as a solidthinking file, however, when opening up the following day, the file was not as I had saved it. Each "optimised" result showed a blank design space with the outline and non-design space shown.
It appeared that I could save these individually and analyse etc.
As mentioned, I wanted to compare all of these together and see which the best solution was.
Is there a way to save the file with these 4 optimised results so that I can open at a later date and continue from where I previously stopped before saving?
Thank you
Can anyone please help with this?
I need to have some further work done for my dissertation presentation t the end of the week and still struggling with this.
Thank you,
