Marcel Laukat
Ploynurb - it's not possible to erase a element
Dear moderators,
I am working on a project in which I used the polynurbs. To make the intersection between design space and non-desing space is quite dificult and I think I created a self-intersection or a bad element. Now I want to erase it but it isn't possible. Every time I try the program creates a new element instead of erasing it.
Thanks for your help!
BrakeSystem.stmod
Hi Marcel,
You can try to put 4 controle nodes on another to repair your model (bridge and surface spit). Be carefull with slicing a model within one surface only - it may not allows you to delete a polycube later! Only Polycubes (smallest part of a PolyNURBS) wich consists of 8 nodes can be deleted easily.
Please find your model attached.
Regards
Felix
BrakeSystem_repaired.stmod
