Sander Van Den Berg
optimization stops at around 58 procent
I downloaded Solidthinking yesterday and have been trying to optimize a simple part with a plate where force is applied to, a fixed rod, and a given designspace. It seems to get stuck around 50% (one time at 58% and a few times at 52%). After running for around 3 hours I deleted one and retried it. After a while it gave the error 157. I am not sure what I am doing wrong. I am running it on a HP Zbook studio G3. I attached a reference image below of the set-up. I hope someone will be able to help me further.
Inline images 1
Hi Sander,
Welcome to the official sT Forum!
You are facing some perfomance issues, caused by extremly thin volumes, you should create a 2D representation of. Therefore, please use the "Midsurface" tool on the thin parts of your assembly. You will mention no visible thickness (2D) representation, if this process is successfull.
As a result, your Simulation will be extremly fast.
Hope this helps!
Regards
Felix
You are welcome!
Glad to hear that - you can always check contacts within the Structure tab -> Contact -> in your case it should be highlighted in blue.
That "floating" is just a visual gap.
Regards
Felix
