Sign in to follow this
BradK
New Install - file missing on compile
Hello All,
I just installed the embed software on a machine with a fresh install of windows 10, 64bit.  I installed CCS with support for the C2000 processors.
Following installation of the embed software I tried to  compile and run the LED blink example for my device.  I am using the LAUNCHXL-F28379D Launchpad.
When I compile the code I get the following error at the end of the compile output:
C:\sTEmbed2017\cg>lnk2000 --display_error_number  --diag_suppress=16008 -c -x -q -mblink283x.map blink283x.obj   -l lib\SFO_v8_fpu_lib_build_c28.lib -l lib\ii_F280x_fpusr.lib  -heap 64 -stack 128  -o blink283x.out lib\F28379cpu1""lnk.cmd
error #10008-D: cannot find file "lib\F28379cpu1lnk.cmd"
warning #10062-D: entry-point symbol "_c_int00" undefined
Seems there is a missing file.  Any assistance in fixing this situation would be greatly appreciated.
Brad
