Mario
Presentation of results - Inspire / Hyperview
I have a question regarding the presentation of results.
Find attached two pictures of the same result presented in Inspire and Hyperview (from scratch directory. fem & h3d).
You can see the result of a screw pretension. The stress distribution look extremely different and i'm a little bit surprising.
Is there any reason for that?
Best Regards,
Mario
Pretension.stmod
Hi again,
The "Autocalculate Meshsize" of both parts is switched off and min. is 1mm, max is 5mm.
There is nothing more to do, only run a calculation. If it is not comprehensibly, then i can send also results (but the file is much bigger, since you need also the h3d for Hyperview).
Version i'm using is Inspire 2017.3.1 build 8625.
Best Regards,
Mario
Hi Felix,
The asymmetry is not the problem, but the stress distribution does not look plausible.
Corresponding to the pressure cone (area) of a screw connection, the highest load should occur at the top.
Best Regards,
Mario
Mario,
You might would like to decrease element size to get a more detailed look at the stress distribution. For my point of view, there is all right.
We can clearly see the maximum peak of sheer stresses below the surface - so the van mises stresses.
This effect is discribed in the Hertzian compression theory, which can also explain defects like pitting.
BR
Felix
