uri
Domain error: Argument not in valid range
When trying to calculate (solidification) with sleeves I get an error message:
Error when preparing data for analysis (Domain error: Argument not in valid range)
The calculation is O.K. without sleeves.
Please advise.
Hello Uri,
The problem is there is no ingate on this model.
Please, start again from the scratch and mesh again using an ingate. This should solve the problem.
Best Regards
There is a problem when the ingate surface is in contact with one of the surfaces of the additional components (sleeve, core,..)
Meanwhile, in case you have this situation, please extrude just an small offset of the face in order to separate the ingate surface from the sleeve surfaces. (see below image)
We'll work to solve this issue.
Please, find below a link to download the file with the ingate meshed.
https://ftam1.altair.com/message/m40gPhijtxxbaxGThmKcbB
Best Regards
