ilin.engineering
Sheetbody analyze failure
Hello!
I want to optimize the beam, but system showes me "Unable to run"
Progress.log file consist of:
# -------------------- Progress Tracker --------------------
hwfdmfeprocessor process id = 6900
# Opening Model
# Model opened successfully
Client  = Inspire    18.0 9508
Name  = model1 (2)
ModelName  = Model
stmodOffsetId  = 2
# RunType: OPTIRUN_ANALYSIS = 1, OPTIRUN_TOPOLOGY = 2, OPTIRUN_TOPOGRAPHY = 4,  OPTIRUN_SHAPE = 8, OPTIRUN_GAUGE = 16, OSSMOOTH_REANALYSIS = 128
RunType  = 1
# Using CAE_HOME='C:/Program Files/Altair/2018/sTInspire2018/unity/bin/win64/'
RUN_STATE = 1 ## Run started
RUN_STATE = 3 ## Generating fresh mesh/Using old mesh
#--------Generating fresh Mesh
#--------No solid parts found
RUN_STATE = 7 ## Meshing completed successfully
RUN_STATE = 15 ## Realizing model
#--------Unable to populate mesh data for sheet bodies
#--------Unable to realize
# Error - Unable to ralize synthesis data
RUN_STATE = 1039 ## Done
# --------------------- END -----------------------
Please, help me to solve thiis problem!
model1.stmod
Dear Ilin Engineering
I would suggest to convert your sheet surface to a sheet body with the push/pull commando. Instead of specifying a plate with a thickness of 0.01m, you increase the thickness of the plate with 0.01m in order to obtain a body. When I do this, I am able to analyze the model. In the attachment you can find the adapted model. I hope this will help you.
Michael
model1.stmod
