rahul1
Loads are insufficient to produce a shape
I have a problem with min max optimization.
the geometry optimized with max. stiffness but the same geometry with the same boundary condition cannot optimized with min mass
No Shape Created
Loads were insufficient to return a result. Check that realistic loads are applied to the model.
Hi Rahul,
Well - I think the issue is quite clear isn't? You are trying to run an optimization, which can't be achieved with the Boundary conditions you applied.
You could play around with them to find out which it is - and change it.
If I would have to guess: Your min. elementsize is too large or there is no solution possible with the direction of your draw-direction.
-Felix
