Sign in to follow this
Lala
lattice optimization
hello to all .Can anyone tell me how to view design violation error after lattice optimization-(i am getting often).
How to view that what design violation one has made?
and also i want to ask that is there's a standard procedure or method to do lattice optimization?
I didn't found any relevant document explaining the issues.
Hello @Lala
I see noone hasn't answered you yet. The lattice optimization in Inspire is performed in two phases: a) topo optimization, b) lattice optimization. In my opinion the reason why you have design error mark in lattice optimization result is that you simply can't reach the objective (for example: you wanna have 100% lattice filling) with the parameters you have prescribed. I performed an example:
a) 1st run
target length = 6 mm
min diameter = 1 mm
max diameter = 3 mm
safety factor = 2
lattice filling = 100 %
-> ERROR mark in results
b) 2nd run
min diameter = 1 mm
max diameter = 3 mm
safety factor = 1
-> results OK
So what can I say about it: In my opinion Inspire is a little bit dummy in this type of optimization. Because if you wanna perform a lattice optimization you have to overestimate topo optimization results.
