MarkL
Evolve vs 3d Studio Max
Hi I am soon to have an interview with a company I  applied to that are dealing with architectural product design. (furnishing design, benches, playground parks etc)  The company uses 3D studio max as their main concept design tool. I hope they are open to other design packages as I am reasonably versed in Evovle but not 3d Max. I think I may be in a situation  to try convince the employer to purchase evolve as I find it much better tool for product design. I  would try to explain to the employer that 3d studio max is generally catered towards animation/film industry whereas evolve is for true product design.. However,  I lack a solid convincing argument to convince the employer to go ahead and purchase Evolve. What could you suggest me to tell the employer why Evolve would be better option than 3D max for architectural product design?  I could then have more solid argument and hopefully be able to convince them to get Evolve. Your suggestion is urgently needed. Thanks.
Mark
Hi Mark,
Construction History, PolyNURBS, and real geometry are the three main points.  All models made in Evolve can be used directly for manufacturing since it is actual surface and solid geometry rather than polygonal.  Complete history gives the flexibility to edit/update features, dimensions, etc...without having to manually rebuild models.  With PolyNURBS tools you have basically the same workflow and ease of concept modeling you find in products like 3d Max, but the big difference is that your models are NURBS based, can be used directly to create molds, tooling....and can be combine with traditional surface and solid modeling tools for increased control and precision modeling if needed.  And obviously you have integrated rendering so no loss in visualization.
Without knowing the companies process for producing products I can only assume they are sending out 3d Max models to be recreated in a CAD package in order to create models suitable for manufacturing.  In this case there is usually some design elements that get lost in translation or inaccurately interpreted.  By switching to Evolve it would give them more control over the products they are creating and also save them money in time and services needed for CAD support.  Again this is all based on many assumptions.
If you end up going with this company and are having difficulty convincing them to use Evolve you can contact me directly at chilton@altair.com.  I'm sure we can arrange something to convince them and allow you to continue using Evolve.
Thanks,
