yypengpengs
An unhandled win32 exception occurred in WallMan.exe
Dear all,
When I use WallMan to convert data, I suffer this error every time. I don't know why. I have modified the real debug in Visual Studio and browser, but it still doesn't work. Could anyone help me? I would really appreciate it if you could help me.
I will need a few more details:
(1) what version of WinProp are you using?
(2) what type of database are you trying to convert? i.e., the extension of the file - is it a .dxf file, .osm file etc..?
(3) I want to confirm that you are indeed trying to convert your database through the API.
26 minutes ago, ngoy said:
Thanks for your reply.
I use the WinProp 2018 student edition.
I tried to convert .osm file download from Openstreetmap to .odb file that can be read by ProMan.
I can successfully convert .osm files with no problem with version 2018 (student ed.). The problem you have seems to be unrelated to WinProp but more related to the set up you have on your computer (your Visual Studio installation).
Please have a look at the solutions suggested in:
 https://social.msdn.microsoft.com/Forums/en-US/24b356ad-59ef-446f-aa8b-df6b55fa78bb/an-unhandled-win32-exception-occurred?forum=Vsexpressinstall
and
https://stackoverflow.com/questions/5668338/how-to-disable-visual-studio-debugger
and
I am sorry that the solutions you have mentioned don't work. What should I do.....:(
I would suggest the following:
(1) Before converting (With your current version of WinProp), make sure the option to launch the database after conversion is not checked.
(2) Update to a newer version by using feko_launcher.exe -> check for updates and try again
Thank you so much!!! The method (1) works!
It seems like that the 3D scene has some problems. When I open 3D scene, the project crashes and proposes win32 error.
By the way, where can I purchase the commercial edition of WinProp?
Thank you very much.
The observered problems with the 3D view indicate that the DirectX DLLs are not correctly installed.
Typically this should work using the updater, but as you still have problems I would recommend to download and install the required DirectX package from the following link:
https://www.microsoft.com/en-us/download/details.aspx?id=8109
For the commercial version please use the contact sheet under the Altair webpage:
https://altairhyperworks.com/ContactUsFormHW.aspx
Otherwise please let us know your e-mail address and we will connect you directly with the Altair team in China.
Thank you for your reply and kindness.
My e-mail address is yuyisun0901@163.com.
I can open the 3D scene after I install the DirectX.
Thank you for your help!!
