pianpianc
How to show scale of the model and absolute values in Hyperview?
1st question:
I am capturing images for documentation, and I need the images from Hyperview. In Hypermesh I am be able to see the scale, however, I can't see the scale in hyperview. Do you have ideas on how to fix this issue?
The first image is from Hypermesh, and the second image is from Hyperview.
2nd question:
Can Hyperview show/displace the absolute XY shear values/contour?
Thank you.
Hello pianpianc,
Answer 1: It isn't possible in Hyperview
Answer 2: You can do it by using the Expression builder. Here are a few hints:
  • You must load your model with the "Advanced" Result-Math Template (see "Load model and results panel")
  • Open the Expression Builder and select your result on the left side.
  • Select the math operation on the right side.
  • See attached picture, how it looks.
  • The result is a scalar, and can be found also in model browser (right click here to edit).
Hopefully it helps, best regards,
Mario
