michal1509
LS DYNA ICFD/CESE results to HyperView
Hello!
I performed FSI analysis in LS Dyna using ICFD and CESE solvers. Problem is that HyperView cannot read the D3PLOT results file properly and not showing fluid domain mesh. Is it possible at all to post-processing CFD results from Dyna in HyperView?
Hi michal1509,
Which version are you using?( it is not supported in student version).
If full version: I think you should load combination of both D3plot and other result file to view the results.
for eg: we load combination of  D3plot and .key file to view crash simulation results. Similarly try different combinations.
if it still doesn't work, please share the result files.
Thank you
