christiankeh
How to use solver step size as a variable within a model?
Dear all,
what is the best way to use the current solver step size of a model within the model itself for further calculation?
A minimum example would be very much appreciated!
Thank you in advance!
Christian
For those, who are interested:
I just found the block that I was looking for - SimulatorInfo from the palette Activate\ActivationOperations contains all the necessary information.
Best
Christian
In palette ActivationOperations component SimulatorInfo.
Possible infos are (according to help):
  • step-size: provides last accepted step-size in the simulator.
  • hot-restart: if the solver is [re]started forgetting all past memory about the solution.
  • phase: the phase with which the model is called/evaluated.
  • effective-time-tolerance: the real value of "Time-Tolerance" used by the simulator if it is set to AUTO
Best regards,
Ronald
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
