beytut
after moving handles changes in mesh
Hello;
I want to optimize the location of the trigger in the crashbox. When I changed the trigger position with the handles,  the mesh changes.  does the mesh automatically correct in each solution (50 iteration) or does it stay the same during the solution?
You can select 2d warpage because the face is not planar and possibility of elements failing in warpage will be more.You  can also use off option and later you can improve mesh quality with 2d autoremeshing.
