Sign in to follow this
yypengpengs
How to show the combined field strength in Proman
Dear sir or madam,
I try to put two sites and two antennas on the map, but when I open the results view to see the field strength/power, I just can only see one of the two transmitters, like the attached pictures show. How to show the combined field strength/power  of these two transmitters?
I use the WinProp student edition 2018.
Thanks for your help in advance.
The superposition of the individual coverage results can be done automatically in a network planning project by RunNet. For this purpose you would need to define a network planning project in ProMan based on the corresponding air interface (wireless standard definition file *.wst).
Without network planning project (i.e. in a propagation project) the coverage of individual Tx antennas/leaky feeder cables can be superposed in ProMan by using the following steps:
First load one of the results (preferably *.fpp file) in ProMan via File => Open Result and then superpose the next result via Edit => Combine Data => Max Value (can be done for further results in the same way).
Thanks for your help.
Can I see the 3D view under the combined results? As I know, the 3D button is grey.
