Saurya Mishra
Automated simulation and capturing data
I am trying to do a Monte Carlo simulation on my model. I am varying the inputs based on a Normal distribution to see how the output behaves.
I need help with 2 things here.
1. Is there a way to automate the execution of the simulation, so that it simulates multiple times (say 1000 times)
2. is it possible to capture the data in a .csv file by appending it, so that i get data from all the simulations, and that it is not overwritten everytime the simulation runs.
BR
Saurya
Hi Syurya,
I have no exact solution for your task, but look at the example "moonlanding_opt.scm" in Demo Browser, Activate, Games. The combination of elements in super block "next last" and "Restart" in "optimize" allows you to run a defined number of simulations.
The ToCSV block overwrites the file at every new simulation :(. I suggested a modification to the development team, but expect it not before next release. You can try to write your own C block with fopen(filename, 'a') (or similar). It should be easier than the output of an event activation ;)
Best regards,
Ronald
Ciao Saurya,
Please here you find a possible solution implemented using Activate 2019.
1- Open Activate2019 go under tools->oml editor and load Master2019.oml.
This file is the master that will generate a new input file (input2019.csv) for the Activate model (Slave2019.scm) at any iteration of the for cycle and will run in batch mode
the Activate model Slave2019.scm.
2- Slave2019.scm will generate a different csv file for each run (authomatically named run1.csv, run2.csv... so that it is easy for You to identify which run the data refers at)
3- To run the example just remember to adjust the paths according to your installation (also inside the *.bat file).
4- Unfortunately for the moment isn't possible to append the data in the same .csv. A possible solution for that may be to do only 1 run longer (final time= time for a run * runs number)
and change input when (simulation time) / (time for a run)=integer number.
Best Regards,
Liv
Master2019.oml
runActivate2019.bat
Slave2019.scm
