Arul 3 Report post Posted September 17, 2018 Hi , I am having following queries while trying Modal correlation option in Hyper view - NVH. 1. I am facing error while using transformation option in Hyper view - NVH - Modal correlation. Pls find the below image & help how to sort out. 2. How to use tolerance option in Node pairs menu. I could't able to get the values in the below table Regards, Arul Quote Share this post Link to post Share on other sites
Premanand Suryavanshi 23 Report post Posted September 18, 2018 Hi Arul, 18 hours ago, Arul said: 1. I am facing error while using transformation option in Hyper view - NVH - Modal correlation. Pls find the below image & help how to sort out. This error is shown because, you have not set the reference nodes properly. Please, go through the Help section to set the references properly. HyperWorks Desktop Applications > HyperView > NVH Menu > Model Correlation Utility: 18 hours ago, Arul said: 2. How to use tolerance option in Node pairs menu. I could't able to get the values in the below table For eg: if you give Tolerance value as 100, it will select or display all the node pairs, which has a distance less than or equal to 100. Quote Share this post Link to post Share on other sites
Arul 3 Report post Posted September 18, 2018 Hi, 1.Could not able to sort out the error. Quote Share this post Link to post Share on other sites
Premanand Suryavanshi 23 Report post Posted September 18, 2018 Hi Arul, 1 hour ago, Arul said: Hi, 1.Could not able to sort out the error. Now i see that you got different error (i.e. now the error shows for solid elements). Make sure you have set the references for solid elements too. Thank you Quote Share this post Link to post Share on other sites
Arul 3 Report post Posted September 19, 2018 Hi, The error shows for solid & Shell elements also. How to set the nodes? Is it required to select the same plane nodes for both models? or different plane for two models? Quote Share this post Link to post Share on other sites
Premanand Suryavanshi 23 Report post Posted September 19, 2018 Hi Arul, Please can you share the related output files. Will check at our end and let you know how to proceed with it. Please use below FT link to share the files. https://ftin.india.altair.com:8443/filedrop/~osKE8Q Thank you Quote Share this post Link to post Share on other sites
Arul 3 Report post Posted September 20, 2018 Hi Premanand, Can I get tutorial with step by step for that?? Regards, Arul Quote Share this post Link to post Share on other sites
Premanand Suryavanshi 23 Report post Posted October 8, 2018 Hi @Arul Sorry for the late reply. Please refer below post and view materials shared by Rahul R. It covers video & pdf of model correlation. Thank you Quote Share this post Link to post Share on other sites
Arul 3 Report post Posted October 27, 2018 Thanks Quote Share this post Link to post Share on other sites
