Sign in to follow this
beytut
Hypermorph spotweld optimization
Hello;
I trt to do spotweld optimization( location)  on crash box using hypermorph and hyperstudy . İ change the location of spotweld domains . And ı see its location change in structure.  But when ı run the optimization in hypersrudy it give me failure after 2. Run. İs it possible do spotweld location optimization using hypermorph and hyperstudy?
Hi @beytut
The error is because of the type 2 interface.
Try to increase the dsearch on type 2 interface card,  Default is the average size of the element and set Isearch to 2 and check if that helps.
