AlloyCrow
Error 61 when Trying to analyze an Optimization.
Hello
I am trying to do an analysis on an optimization but I get error 61, I tried changing the Optimization Thickness to different values but can't get it to work.
Unfortunately, I can't share the file. What to try now?
I saw in another post, someone was having this same problem (See link below) but there is no conclusion/solution for it.
I run Inspire 2018.2
My machine specs are
Video: Radeon Pro WX 7100
Processor: Intel Xeon 4cores 8threads @ 3.7ghz
Memory: 16GB
Thanks and Best Regards.
This could be because of several reasons mentioned in above shared post or sometime when loads applied in the design space, this may occur. It would be nice if you could test this in 2018.3 or 2019 version which is available on our website of solidthinking. If possible, please share model file for the test and we will keep it confidential.
