Sign in to follow this
saiful85
Solver Error when using result mapper
I tried to use result mapper to map result from a forming into the next simulation, but i got this error. I use the same model for the forming and the next  simulation.
Could anyone explain whats wrong in my radioss file and how to solve this.
I attached the related files:
 - ballshot (sta) -> state file from forming simulation
- mappedballshot (sta) --> sta file generated using hypercrash result mapper
- rad 000 and 001 file
- out file
Thank you very much in advance.
mapper.rar
BHi saiful85,
Using the result mapper in Hypercrash (2017.2.4.) with the shared files gave similar results. Everything looks fine in HCrash until export:
-deformed shape is not exported
-results are split into 4221 Tables (this is the probable reason for failure)
But I did manage to get the model working using Hypermesh with the procedure (starting from 100mps_10cycle_15hz_simpl_0000.rad):
-delete the Include files
-delete the Tables (all 4242 entries)
-import the solver deck ballshot_13082018_0011.sta file with FE overwrite ticked
mapper_0000.rad
mapper_0001.rad
mapper.hm
Thank you very much Ivan,
That works very well.
But I'm still wondering why i cant use the result mapper to do this. I hope Altair people could clarify me on this.
Anyhow thank you very much.
