SSACHDEVA
Simulating a L shaped Probe fed Regtangular Patch
Hi SSACHDEVA
Some follow-up questions:
  • What version of FEKO are you using?
  • Does this happen for all models, or just this specific one? If it is model specific, could you please attach your model?
  • What is the full path to your model? Does it contain any special characters?
  • Can you run the startup model (%FEKO_HOME%\shared\Resources\startup_model.startup.cfx) when it is located in the same directory as the model that gives the problem and also when it is in a different directory?
Kind regards
Madelé
