Wisawanart
What is the Expression for cutting the T01 into considered range
Dear Altair support team,
I am studying in crash box optimation, I set up the model as following figure, this model is deformed until reach incompressible condition (To observe total crushing performance), as a result the force goes up considerably after 120mm.
However, I need to consider the data between 0 - 120 mm (78% of total displacement), but I can not find the Expression for cut the data in HyperStudy.
          According to the figure below, that show you the Force and Displacement collected from T01 file, how can I trim the data range from 0 - 120mm using some Functions.
Below this, there are output responses that already create but need to select the appropiate range first.
D_i.PNG.da3e9c3483326cd04b9f38978f86bff6.PNGF_i.PNG.9858500d9111fc74cd111023c985c6e6.PNG
If you need further information please do not hersitate to let me know.
Thank you for your help
Best regards,
Nut
