Franz_M
Load cases using include files, manage include files for each load case
Hi All,
I'm trying to set 2 load cases (static) using include files. The aim is to apply 2  loads on the same object (or a part)  in two different positions.
The scheme is as follow:
I can create include files, one for each position, I can't manage these files for each load case.
Is there a manual for this or can you explain how to do it?
thank you
Ok, It's clear, so, in other words, it 's impossible to change stiffness matrix in a single run , specially in linear static.
The only way is to create a bach file on windows to run consecutively two "master". Do you know the command line, for Optistruct, to start a sequential run and not a parallel? (I knew for Nastran there were two different command for sequential and parallel run execution)
Yes,
Once you have 2 master *.fem files, just select them as "Input file(s)" on Hyperworks Solver Run Manager , optistruct will queue them (sequential run)
