Nachiket Kadu
Node number for independent node of RBE2
If you have many rbe2 and indep nodes are not in shell comps:
In panel 'entity set', select nodes>by collector> click to select shell comps>select>reverse
If indep node is closed to other, activate 'concide picking' in menu preferences>graphic options
@tinh Thanks for your reply.
I tried this now, still i cant procure the the independent node number.
