I'm running a crash simulation in Radioss and I have requested a T file to be written. When I try and load the T file (T01) in hyperview and in hypergraph an error comes up saying it was unable to recognise it. I set the type to 0 default and I also tried 4 because I believe hypergraph can read that. I think data is being written to the file because the file size is fairly large. Any help would be appreciated.
_ront_bumper.crashT01
Hi @Aidan B
There are few instances where the files get corrupted. As a workaround, you can convert the T01 to .abf using HGTRANS and use the same for plotting.
Conversion usually takes some time depending on file size, so don't worry for you see the HGTRANS says not responding at the top.
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
